gel coat discoloring
Old 08-30-2008 | 08:27 AM
horsplay's Avatar
Default gel coat discoloring need help
have all these gray dark areas in gel coat seems to be inside not on the surface, tried to wet sand small area nothing works, definately inside anyone have any ideas? will post some pics
Attached Thumbnails gel coat discoloring-img_3166-copy.jpg   gel coat discoloring-img_3182-copy.jpg   gel coat discoloring-img_3184-copy.jpg
horsplay is offline
Old 08-30-2008 | 07:42 PM
Default When the boat is made some times , well almost all of the time
they use black gel to back up the color of the boat. Looks like thin white gel and some aligation. They sprayed the black back up gel to soon after the white. A small wet sand and buff would tell you. If it gets worse you know your ubbing through to black gel.
Bill
Bottoms Up is offline
Old 08-31-2008 | 06:51 AM
horsplay's Avatar
thanks for your reply , what is aligation ? and do you not think it is water infiltration.
horsplay is offline
Old 08-31-2008 | 07:03 AM
Default Aligation is
the definition used for when two colors of gel meet and molt in the part. Gel coat is gel coat no matter what color so you should not see any infiltration. Find a moisture meter and you can tell. Run it over a good spot and measure and then over the bad spot and see what you get. Repair houses such as myself should have one.
Billy
Hope this helps!
Old 08-31-2008 | 07:57 AM
horsplay's Avatar
thank you
horsplay is offline
Chris288
Detailing, Painting, & Fiberglass
7
09-20-2007 04:31 PM
Fenderjack
14
02-14-2007 07:22 PM
pb
7
08-24-2005 01:19 AM
Pure Energy
02-21-2003 07:05 AM
