Clear Coat over Gel Coat
Old 08-10-2005 | 09:55 AM
pb's Avatar
pb
Default Clear Coat over Gel Coat
On my Aggressor the deck has pruple gel coat graphics that I am playing hell with to keep from chalking. I had the entire boat buffed in the spring which came out great but the purple is clouding up already. The white of the deck still looks good.
Is it possible to mask off only the purple graphics and clear coat that area only.
What would be the procedure in doing this and also the best product to use.
Paul
pb is offline
Old 08-10-2005 | 10:41 AM
jspeeddemon's Avatar
Default Re: Clear Coat over Gel Coat
I was told by Sher-Fab that clear over gel is no problem.
jspeeddemon is offline
Old 08-10-2005 | 10:46 AM
Audiofn's Avatar
Charter Member #232
If you do this you need to make sure that ALL your chalk is gone before you clear it or you will see it though the clear and obviously never get it out.
Jon
Put your best foot forward!
Audiofn is offline
Old 08-20-2005 | 01:29 PM
I had a boat that the top was clear coated and was maroon and black and never faded(it works) and some of the clear coat started peeling and the fade was bad in the spots that were not protected I would ask your local body shop about doing it.
Good Luck!
chuckgo6 is offline
Old 08-20-2005 | 02:09 PM
customtouch's Avatar
Yes, It is possible to just spray clear over GelCoat. However if you are going to the trouble of masking and prepping the intire suface of the purple anyway, you would be better of to spray on more purple before clearing it again. This will insure that the color will not oxidize again and (if done properly) guarantees a permanent solution. The extra cost of the base would be minimal but worth its weight in gold if you plan on keeping the boat for a while! It will be the same amount of labor either way. I have had to deal with this situation many times in my buisness.
customtouch is offline
Old 08-21-2005 | 10:36 PM
pb's Avatar
pb
Thanks for the responses,
I spent the afternoon rubbing out the purple areas and then waxing the entire deck. Looks great but do not want to do this every month. Plan B for next year.
Paul
pb is offline
Old 08-23-2005 | 11:14 AM
Wet sand the purple then clear it. Looks perfect. Plus, the sanding assures proper adherance.
ThirdBird is offline
Old 08-24-2005 | 01:19 AM
Either sand with #400 then clear (wipe with wet rag [H2O] to see what it will look like cleared) or as customtouch states, a good single stage color dusted on top B-4 clearing will guarantee a uniform color and will be alot deeper in apperance as well as more UV protected. Single stage urethanes eliminate the use of a primer/sealer that a base coat would need for adhesion. Tape off stripe, de-wax then ScotchBrite with a 3M #7447 maroon pad (like #320). Good Luck!
Gmoney52 is offline
outlaw 32
Baja
4
05-14-2008 10:49 PM
Chris288
Detailing, Painting, & Fiberglass
7
09-20-2007 04:31 PM
jayhawk261
10
04-02-2007 03:30 PM
Fenderjack
14
02-14-2007 07:22 PM
Pure Energy
02-21-2003 07:05 AM
