F 350 Pulls To The Left When Braking >
Old 09-03-2008 | 09:13 PM
Default F 350 Pulls To The Left When Braking
HAVE a 2001 f 350 4x4 140.000 miles on it 7.3 when i hit the brakes it pulls to the left real hard and bounces a little , thinking ??? brake line or caliper , help !!
elroy521 is offline
Old 09-03-2008 | 09:34 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It could be a lot of things; tire, brake, bearing, hub, spring, shackle, shock.
Do you feel a vibration in the steering wheel when you brake? If so, you probably have warped rotor(s).
Sydwayz is offline
Old 09-03-2008 | 09:44 PM
I had same issue ck the trans mount does it clunk some times?
topgun 38 is offline
Old 09-04-2008 | 01:49 AM
dont gamble on safety issues!!!!
take it to the Ford dealer! it doesnt cost much to find out EXACTLY what the issue(s) are. your life is worth more than a set of pads, or other. so is the family of 5 in the minivan you may slam into and take their lives in an emergency braking situation with your trailer behind you. pulling in the brakes is 99 % of the time easily diagnosed.
TUG-BOAT is offline
Old 09-04-2008 | 11:24 AM
the brakes are good , the tires are good , just put new shocks on , i think its a rotor , thanks for help
elroy521 is offline
Old 09-04-2008 | 12:23 PM
Airpacker's Avatar
check the ball joints. A worn one can cause the front end geometry to change significantly under braking. Also check the comtrol arm bushings, same problem. A warped rotor will cause vibration but a severe pull??? not likelly
Airpacker is offline
Old 09-04-2008 | 12:39 PM
Agree, my truck pulled on braking, had to replace control arm bushings and ball joints. If you have a 140K miles they definitely need replacing if haven't done so, trucks wear those two parts out. I've replaced mine twice in 104K miles on an suv that see's no towing.
Quicksilver is offline
Old 09-05-2008 | 07:36 AM
From: A tree somewhere in the woods in Clarcona Fl.
Have the front brake hoses checked.
Slick02 is offline
Old 09-05-2008 | 08:19 AM
My F-250 pulled with slight braking and the wheels turned. Felt like the tire started following a rut. It was the U-joint for the front drive.
Ken
minxguy is offline
bowtye8
1
01-14-2007 09:13 AM
Von Bongo
27
05-17-2005 07:27 PM
justinVIP
17
11-18-2003 10:43 AM
mats
13
07-16-2003 06:43 AM
Rick252
8
06-10-2003 03:36 PM
