Hydraulic roller lifter >
Old 09-13-2008 | 09:27 AM
Ken N's Avatar
Arrow Hydraulic roller lifter
Installing a new hydraulic roller cam in a 1999 502 MPI. Who makes a good roller lifter?
Ken N is offline
Old 09-13-2008 | 09:33 AM
KAAMA's Avatar
Call "RMBuilder"/Bob Madara of Marine Kinetics in N.Y. and he will set you up with the correct lifters or point you in the right direction. Bob's number is 585-654-8583
KAAMA is offline
Old 09-13-2008 | 10:05 AM
Smitty's Avatar
Go with lifters from Bob. He will recommend Morels most likely.
Smitty is offline
Old 09-15-2008 | 07:31 PM
Wink
In a stock 502MPI engine I would save your money and just install a new set of GM hydraulic roller lifters in the engine. We've been using them for years in mildly sprung motors and never a failure. GM Parts Direct.com for a good price.
Regards,
Ray @ Raylar
Raylar is offline
Old 09-16-2008 | 07:49 AM
mcollinstn's Avatar
Be sure the top of the factory lifter doesn't drop out of the dogbone. This becomes a concern at around .600 lift. Can be visually checked at assy. You don't need fancy gauges to see what I'm referring to.
mcollinstn is offline
Old 09-16-2008 | 12:39 PM
Wink
Boaters who are re-camming there engines or building new engines should also pay attention to the new or replacement camshafts base circle size. A good camshaft company should give you a new proper size core billet camshaft not a regrind and this camshaft even with valve lifts of up to .650" lift should still have a base circle size of about 1.200" which will keep the lifter from dropping down so far it starts having a problem staying contained in the lifter alignment dogbones. We've seen this problem on a lot of engines where the camshaft had to small a base circle from poor camshaft design and grinding not eh net or gross lift numbers!
Regards,
Ray @ Raylar
Raylar is offline
Old 09-18-2008 | 03:42 PM
Strip Poker 388's Avatar
Rob
I think Comp makes a replacment lifter,cheaper than Crane,Chevy.
Try RMbuilder, he probaly can get a cheaper lifter than morel lifters,if $matters?
Strip Poker 388 is offline
bajabob
9
09-23-2008 12:13 AM
ghittner
19
05-14-2007 05:36 PM
Smitty
6
03-22-2005 03:06 AM
Dave1972
31
08-21-2002 08:45 AM
BAD-HABIT
13
05-04-2002 12:02 AM
