broken spark plug >
broken spark plug
broken spark plug
Old 09-19-2008 | 10:17 AM
Ken N's Avatar
Arrow broken spark plug
How can i get a broken spark plug out. The threaded part is still in the head.The nut part sheard right off.
Ken N is offline
Old 09-19-2008 | 11:10 AM
IM4A2Z's Avatar
Hate to say it but if the nut is trashed that sucker is siezed and really stuck in there. You have nothing left to do but pull the head.
IM4A2Z is offline
Old 09-19-2008 | 11:31 AM
Soak it down with pb blaster, see if you can get the porcelin broken out, use a ez out to get into the center and try that, I have used that and has worked for me..Rob
ezstriper is offline
Old 09-19-2008 | 06:23 PM
That'll work !
HALLETT FAN is offline
Old 09-19-2008 | 10:17 PM
tough one???? if you can get a drill straight in I'd try that first before pulling the head. hopefully it was a defective plug and not siezed in the head. good luck
tcuda499 is offline
Old 09-19-2008 | 10:58 PM
Drill left hand bit if possible.
BradH is offline
Old 09-20-2008 | 06:10 AM
Let me guess...Champion plugs? I have had it happen to me twice in cars with Champions. I did what ezstriper said and it worked both times.
JRider is offline
Old 09-20-2008 | 08:45 AM
PatriYacht's Avatar
If any thing falls in the combustion chamber while you're drilling, pull the head off and clean it out. A small piece can cause a lot of damage.
PatriYacht is offline
Old 09-20-2008 | 09:37 AM
Ken N's Avatar
Arrow broken plug
I think i will play it safe and pull the head.
Ken N is offline
Old 09-20-2008 | 09:45 AM
As stated ezstripper his method or try using fast heat from a cutting torch for 20 seconds then drive in the easy out( use the style that looks like a reverse thick cork screw)with a hammer, not too hard and you will get it out. I have done at least 50 plugs and none have beaten me.
Andy is offline
