New Cummins/Mercruiser Project
Registered User
New development with Eliminator...500+hp with 1000# of torque...
Motors are going into this 43' Eagle...
Target delivery is the Ft Lauderdale Boat Show...
If the engine is 500hp the fuel burn rate is easy to calculate. It takes 1 GPH of diesel fuel for every 20hp. So 500/20= 25 GPH per engine at WOT. I would take a guess that it would burn about 20 GPH per engine @ 60 mph.
Fuel consumption averages about .36-.38 lbs per Hp hour. The GPH is based on how many horsepower your using at any given time.
The 25 GPH is close, it most likely will be as high as 28 (dyno) but that "1 GPH of diesel fuel for every 20hp" is probably more representative of what you will see in the actual boat.
Maritime_Eng - that's a very good quick little gauge of fuel consumption, thank you!
