6.7 dodge cat problems?
Old 10-04-2008 | 12:07 PM
northernoffshore's Avatar
Default 6.7 dodge cat problems?
has your truck also had problems? 3 times now to have the catylictic converter fixed and cleaned. The dash light goes on and the truck runs like crap, cause it's clogged up again. Does anyone have a solution to remove this the pollution crap?
northernoffshore is offline
Old 10-04-2008 | 02:35 PM
jmackin's Avatar
Buy a Duramax next time!
jmackin is offline
Old 10-04-2008 | 03:03 PM
tblrklakemo's Avatar
SeaRay Sundancer
Are you talking about the DPF (diesel particulate filter?) If so, than yes, there have been some issues with these on dodge cummins trucks. All three truck makers have had DPF issue of one kind or another. Its a crappy bandaid fix to what the EPA sees as an environmental issue. FYI, your dodge also has a normal catalytic converter that is in your downpipe before the DPF. You can buy a TST race smarty for your truck that lets you turn off the DPF and therefor cut it off. If you have a duramax you must use EFI live. I think PPE has one too, but EFI live is the best for all GM gas and diesel.
tblrklakemo is offline
Old 10-04-2008 | 06:32 PM
I own a FORD but my friends truck that I use left me stranded with the clogging nonsense. Are you still using 4 wheel drive for all that it's worth?
Old 10-04-2008 | 07:25 PM
Expensive Date's Avatar
I have been told that they are having this problem buy customers that are Dodge techs.Was told that they do not like to be idled at all.
Expensive Date is offline
Old 10-04-2008 | 07:44 PM
Downtown42's Avatar
Idling and short trips does not help heat the system up enough to "self-clean the oven". We have had a few issues with Cat and Cummins in Kenworth's.
Our trucks have a switch to re-generate the system manually vs. waiting for the computer to automatically activate it. This prevents being stranded on the side of the highway.
Downtown42 is offline
Old 10-09-2008 | 12:59 PM
Gale Banks claims to have a tuner and exhaust system to help with regen problems;
www.bankspower.com
Hot Knots is offline
Old 10-26-2008 | 08:20 PM
Found a site last night thedieselgaragefourms a lot of problems with this motor.Any one on here have one?If so what do you think?
Old 10-26-2008 | 08:27 PM
there are some bypass products out as well but you will get that smog enviro lecturea along with warrenty speach if its mentioned.
JPD Motorsports is offline
Old 10-26-2008 | 08:31 PM
the dpf systems in gm,ford and dodge trucks are having loading up problems,and watch additives in your fuel system,i know on the gm's guys are removing the dpf's and straight piping them and using ''efi live'' to reprogram the computers,,this is all thanks to the congress and epa
dmaxx3500 is offline
