Oil Bath Axles ??
Old 10-13-2008 | 09:41 PM
Poker&Run's Avatar
Default Oil Bath Axles ??
Wanting to get some feedback from anyone using and oil bath lube system. I am rebuilding my trailer axles and considering getting away from grease. Ranger Boats has been using this type of system for several years but I don't see it on offshore applications very often.
Feedback??
Poker&Run is offline
Old 10-13-2008 | 09:46 PM
I personally do not like them, if the seals fails you are guaranteed to get water in them and fail immediately. Plain old greased roller bearings have worked pretty well for a hundred years and they will last a lifetime with proper maintenance. I have had friend that did the right things with oil bath and still had a seal fail and burned up a hub.
happy hours is offline
Old 10-14-2008 | 08:59 PM
excursion's Avatar
Oil bath suck, my brother in-law had to have them 3 months later and alot of leaking he went beck to grease. I just bought all new disc brakes for my trailer and will have grease on mine.
excursion is offline
Old 10-14-2008 | 11:05 PM
copiercat's Avatar
loadmaster used them exclusively for a couple years and needless to say they replaced them with old grease and douple lip seals systems.if that tells you anything
copiercat is offline
SinkorSwim
Swap Shop
0
07-18-2008 11:27 AM
Jim Diesel
9
06-26-2006 10:36 AM
Dusty Times
5
06-11-2004 10:50 PM
JnT
7
07-20-2003 01:34 PM
