Jetting
Old 11-09-2008 | 11:11 AM
Default Jetting
On a NA BBC with a single carb (mine is a Dominator), do you stagger the jets front to rear? Assume the impact of the PV's is neutral. I am looking for the amount of your jet stagger, if any vs. the actual jet size.
BenPerfected is offline
Old 11-09-2008 | 11:14 AM
Oh...also single plane intake manifold.
Old 11-09-2008 | 12:45 PM
With the same PV's in primary and secondary, my 1050 on my 525sc was squared as stock. After I did some mods and rejetted, I bumped the secondaries up 2 sizes bigger.
Griff is offline
Old 11-09-2008 | 02:42 PM
Griff,
Are your plugs approx the same color? Square jetted with 2 PV's I am rich in the front - 1&3 and 2&4. I am done for 2008, but just working on the 2009 plan
Old 11-09-2008 | 07:36 PM
This was on my Pantera engine. All the plugs were pretty much white on the porcelain. They had good color on the base circle and they all looked the same. The fuel charge was probably more balanced on mine since it was going through the SC first and being forced in with boost.
Griff is offline
Old 11-10-2008 | 07:36 AM
I have a domminator on my 540. It was done by nickerson. It has 92 jets in the front 94 in the rear and 4.5 power valves in both front and rear.
fbc25el is offline
Old 11-10-2008 | 12:01 PM
fbc25el,
Does your plug color indicate the same A/F ration in each cylinder?
Old 11-10-2008 | 01:08 PM
Yes it does. Depending if it is real hot and humid I might hafto turn the idle air bleed screws a 1/4 turn in or out. I am also verry happy with nickerson's work.
fbc25el is offline
randy carlson
3
03-18-2008 07:07 AM
KCHOTBOAT
5
06-29-2006 02:02 PM
HARRISONMIRAGE
3
07-21-2004 09:20 PM
jryan26
5
05-14-2004 05:36 PM
Excalibur
5
04-30-2004 03:07 PM
