Go Back  Offshoreonly.com > Owners Forum > Banana Boat
Tramson Bracket >
Tramson Bracket
Tramson Bracket
Old 11-27-2008 | 11:43 PM
Default Tramson Bracket
Thinking of putting one on, including swim platform, with about a 8- 12" setback an along with a rmanual-jack, about 4-6". I'm thinking of a toal of about 12-16" of setback, does these sound about right? oh, twin Loopers, about 240HP each will go on the boat. Any suggestions at all would help a lot, thanks!
INXS2 is offline
Old 11-28-2008 | 03:39 PM
I spoke to some who makes and sells the brackets and he told me that the norm is 1" set back for each ft of boat and that the motor can mount right to the bracket and there's no need for the rapid jack or any other type of mount. Also the new Banana Boat seems to have about a two ft set back, though it only has one outboard.
INXS2 is offline
Old 11-28-2008 | 08:19 PM
mrv8outboard's Avatar
coolrunning racing
banana's work well at 17"s of set back. remember when moving the motors back the CG is also moved back. go with a "Porta Bracket" and just have the make the top as wide as you want your platform.
mrv8outboard is offline
Old 11-29-2008 | 01:32 AM
Sorry I'm not up on the terms? I'm putting twins so I guess you mean I should use two seperate brackets?
is there that much of a difference if I use a full with the swim plateform? I think the new 24'er has it with a single OB, could I get away with it with twins?
INXS2 is offline
INXS2
3
11-17-2008 07:21 AM
thedonz
Wanted
4
09-03-2008 02:01 PM
cig1988
3
05-07-2007 03:09 AM
open wide
11
03-22-2005 10:58 PM
BAD-HABIT
5
04-04-2002 12:23 AM
