Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Advice needed with repair >
Old 11-30-2008 | 08:02 PM
Default Advice needed with repair
Well I was preparing a corner in my boat to re-glue a portion of the carpet that had come up when I noticed that the fiberglass cloth holding the deck to the hull was beginning to separate. I pealed of a section to get a better look and decided it was time to repair the area. Please look at the pics below and give me your thoughts.
I am pretty confident I can make this repair but wanted to get some advice.
How should I prep/clean the area?
Can I use fiberglass tape or what material should I use? (please be specific on ounce and type)
After preparing, can I just wet it out with standard epoxy and hardener or do I need to add anything else.
Thanks for the help.
http://i509.photobucket.com/albums/s...h/DSCN0280.jpg
http://i509.photobucket.com/albums/s...h/DSCN0281.jpg
Malibu97 is offline
Old 12-02-2008 | 08:24 PM
Default Get a vacuum
and grind the old glass off. Make sure it is dry. Cut up some sqaures of material,if what we see failed then you need to go thicker. two layers of 1.5 oz mat and a layer of 10 oz triaxle or a layer of 18 oz roving.
Not to thick and cure it mild, no hot spots.
Billy
Bottoms Up is offline
Old 12-05-2008 | 09:19 AM
"two layers of 1.5 oz mat and a layer of 10 oz triaxle or a layer of 18 oz roving."
Can I just go with some 18oz woven roving?
Malibu97 is offline
sonic28
3
07-14-2008 01:57 PM
FLYWITHME
4
05-31-2006 11:07 AM
fruitta55
Banana Boat
12
07-24-2005 08:59 AM
powerguy
1
01-18-2004 06:01 PM
Nut
03-19-2003 07:50 AM
