Power Steering Pump?? >
Old 03-12-2002 | 01:14 PM
cigarette1's Avatar
Member #2 ....Jeeezz
Question Power Steering Pump??
I've come across a method to eliminate the power steering pump from my full hydraulic external steering.
Probably some of you old-school racers can give some pro's and con's to the method.
Pressurized power steering fluid tank ???????
My pump is shot and I need to do something ASAP and this sounds workable to me.
cigarette1 is offline
Old 03-12-2002 | 01:19 PM
blown formula's Avatar
do a search on this subject... I started a post about this about a 4-6 weeks ago. The bottom line was, there was no current substitute currently available such as a 12 volt or other hydraulic pump to handle the flow requirements of a full system.
Has this changed, anyone????
blown formula is offline
Old 03-12-2002 | 01:31 PM
cigarette1's Avatar
I remember reading the string ... but I don't think you mentioned having the system already pressurized ... I think you were trying to figure how to pressureize the system without a steering pump.
I am talking of pressurizing the system and holding the pressure.
Old 03-12-2002 | 01:47 PM
cigarette1's Avatar
How much pressure would a steering pump pump if a steering pump could pump pressure???
Or,
How much pressure should a steering pump generate?
Old 03-12-2002 | 02:00 PM
sorry, I cannot answer those questions. they are unknowns to me. Hydraulics is someone else's specialty!! I wish I knew. Sure would be nice to eliminate the pumps, but the air pressure adea seems too easy .
Old 03-12-2002 | 02:15 PM
Katdrvr's Avatar
I think the hoses are rated for around 2000 psi.
mike
Katdrvr is offline
Old 03-12-2002 | 03:55 PM
I think you can do this with a different hydraulic helm. I think it is called a Capilano self contained helm. This is what outboard guys use for their hydraulic steering. It may make the steering a little stiff, but getting rid of the power steering pump would free up some hp and clean up the motor a bit. I'm sure someone has tried this.
WETTE VETTE is offline
Old 03-12-2002 | 04:56 PM
Biggus's Avatar
Thumbs up
I used to have a 24' Bannana boat with twin TRS drives and it had full hydraulic external steering with a pressure tank. There was no power steeering pump, it worked great. The system was by Hynautic in Fla.
Good luck, Kurt.
Biggus is offline
Old 03-12-2002 | 05:19 PM
i have a hynautic system on my little boat thats for sale. it is basically a pump at the helm, a pressurized accumulator tank, a couple hoses and a cylinder. at slow speeds it's a little more work but it's also less stuff to break and less parasitic horsepower loss.
excaleagle42 is offline
cigarette1's Avatar
Ding .. Ding .. Ding
Kurt, that is the answer I was looking for. I was just at a friends shop and we were bleeding his steering on a 27 Magnum with the Hynautic system. The only area I question is the size of the steering rams. They were much smaller in diameter with a small shaft. Can this application be used with the larger rams being used today.
Kurt, can you compare the feel or steering effort betwen the Hynautic and using a power steering pump? And, would you reccomend this setup on a larger twin.
G
