Steering
Old 12-17-2008 | 10:29 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default Steering
Maybe you guys can help me again!My fountain with factory external steering two rams.What would I have to do to be able to get rid of my power steering pump.And can it even be done with out replacing the rams,and changing everything. Thanks JOHN
Fenderjack is offline
Old 12-17-2008 | 11:29 PM
I just have to ask. Why would you want to get rid of the power steering? I'm lost here.
Darrell.
DMOORE is offline
Old 12-18-2008 | 12:46 AM
It's not a problem at all. Email or phone if you like and I can spec out the right helm pump for your application. Like Darrell says though, why?
[email protected]
604 315 0570
HaxbySpeed is offline
Old 12-18-2008 | 01:17 AM
Fenderjack's Avatar
Default steering
Well I really didn't know that pump was necessary,Never had a boat with the steering pump,just had a helm and cylinders I need to run the pump low on the fuel pump side and can't find any brackets,Would a small GM style remote fill pump work?????I have cam drive water pumps and the steering belt is a issue. Thanks JOHN
Old 12-18-2008 | 01:38 AM
Fenderjack's Avatar
Default steering
If I keep the pump could I run a smaller pulley on the crank to get my clearance I need. What would that do to the operation of the set up. Thanks JOHN
Old 12-18-2008 | 01:54 PM
The remote pump will work fine, and using a smaller pulley on the crank for clearance is fine also. It will slow the pump down and flow a little less volume but probably would only really be noticeable at idle and wont cause any issues when cruising.. Either one of those is probably a better solution then swapping to a manual system.
Old 12-19-2008 | 09:33 PM
monstaaa's Avatar
you can install an electric hydraulic unit . they are made by latham for outboards, but i would call latham first. you can also use the pump asked about or you can buy a kpm pump which is very small and universally mounted.
monstaaa is offline
PARADOX
09-06-2007 06:46 PM
26sonic
Sonic
1
05-03-2006 10:09 PM
Excalibur
7
07-07-2004 02:59 PM
CHAOS REIGNS
5
12-11-2002 07:56 PM
patrick22309
2
04-09-2002 01:24 PM
