Moving the motor forward.
I was wondering How I would move the motor forward as far as the rear engine mount on a bravo style boat where the bellhousing is the mount. I WANT TO MOVE IT FORWARD 1". iS There a bellhousing with a adjustable mount or do you have to make a spacer for the inner transom.
How would that work, surely you need the splines of the shaft to engage in the drive plate? Hence the reason for the min/max measurement for the transom thickness.
Although the snout on the coupler sticks out farther, I'm not sure if the spines extend at all. They definately do not extend the entire length.
