36 with 575's
What real life speeds are people getting with the 575's in the 36? Is anyone using the Arizona Speed pully and ecu upgrade and if so how much did that improve performance. Lastly, has anyone done the Superchiller upgrade and what improvements did you see also. Thanks
I use the Arizona kit. Like Obrien said: 118-120 GPS with 1.35 ratio, 36P bravo props, 5600-5700 rpms, sometimes on limiter, and sportmasters, no intercooler. It is a minor upgrade, but helps a little.
throw the intercooler in there with the pulley swap, and the boat should get to the upper 120s.
I am sure you all have allready seen this one.? Just one i know of with the chillers on it. Motivated seller, Tell him Jason told you to call,
http://extremeautogallery.com/01Spectre.html
