Power steering pump bolts breaking >
Old 01-12-2009 | 06:04 PM
Thunderstruck's Avatar
Default Power steering pump bolts breaking
Why does the lower stud on the back side of the pump keep breaking? I have had this problem over the years but it hasn't hurt anything. Just thought I would get energetic and do something about it if there is a solution.
500HP carb, V-Belts GM style pump.
Long time cult member.
Thunderstruck is offline
Old 01-14-2009 | 08:12 PM
Mr Gadgets's Avatar
Charter Member #601
Tom,
Mine kept breaking so I headed to the Auto parts store and bought an exhaust stud and some washers. Installed the stud and finished the weekend. Figure I would fix it later.. never broke again?? Maybe this year with the blower on it will?
Dick
Mr Gadgets is offline
Old 01-14-2009 | 08:20 PM
Thanks Dick. I'll find an exhaust stud. I should've known you would have a fix.
Talk to you later tonight.
Tom
Old 01-16-2009 | 10:50 PM
HotPursuit's Avatar
Install ARP bolt or stud,well worth the $!! My engine package has ARP in everything and I have never broken any. SS bolts from the hardware are very soft.Try and cut ARP with a hacksaw.
HotPursuit is offline
Old 01-17-2009 | 07:53 AM
The studs I broke aren't SS they are the factory Merc studs. Good point though, I will look at ARP regular steel.
Old 01-19-2009 | 10:29 PM
HotPursuit's Avatar
Old 01-19-2009 | 11:08 PM
axapowell's Avatar
Where To
You know I had the same problem 2 years ago. I replaced the stud with a factory Merc one, but was careful not overtighten the nut. Never broke another one, but I do carry a spare! Carbed HP500 type set-up.
Dave
axapowell is offline
Old 01-20-2009 | 07:16 AM
I replaced mine with a grade 8 bolt and used washer for spacers and have not broken this set up yet. Beewn at least 4 years.
Allen
29scarab10 is offline
Revd Up
5
07-01-2007 01:03 AM
Jeff Pierpont
2
04-03-2005 03:53 AM
Smitty
07-08-2003 10:13 AM
Johno
4
06-30-2003 05:21 PM
fishead
1
06-18-2002 09:42 PM
