Holley 800 or 830cfm Whats the differance >
Old 03-14-2002 | 10:06 PM
1Boatnut's Avatar
Default Holley 800 or 830cfm Whats the differance
Ok,I posted on converting a 502 to a hp500 and 1 of the things I will need is a carb. I have been told Merc uses the 800cfm carb. Is this true ? I was looking in CP Performance and the 800 has a manual choke.Can this be used without the choke,and if so what do you do to disable it. I also see in CP Performance the Holley 830cfm. It states it is race calibration. I was told that it is the same as the 800 only it has no choke and it would be equivelant to a bluprinted carb from the factory. IS THIS TRUE ? I also am told there is a 800 cfm with electric choke,but I dont see it listed.Is this true. ANY and ALL help would be apreciated. Sorry for such a long post but these carbs arent cheap. Anyone selling a 830cfm at a decent price?
Thanks Paul
1Boatnut is offline
Old 03-14-2002 | 10:55 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Yes, the HP500 use the Holley 800 w/electric choke. You can buy the manual choke carb and just wire it open to not use, or remove it all together. Chokes aren't a real big needed thing on boats as in cars, unless you go boating in snow. But do make warm up a little easier. I don't have a choke on my 1050. 1 pump and she fires right up. Or you can buy the electric choke kit for $40. OR you can check out the 2 ads in the classifieds section for the Holley 800's for sale.
US1 Fountain is offline
Old 03-14-2002 | 11:16 PM
The 830 should have 4 corner idle makes a big cam idle a lot slower they use a 850 carb body and a 750 base plate most are annular discharge better mixture control and better air speed in the carb.Marine usage dont worrey about 800 vrs 850 I like the 4 corner idle with front and rear power valves the race or hp will have this at around 400$ from summit or jegs for the 830.I dont run chokes I like to let my eng warm up for a couple of minutes that is all it takes.
fstboater is offline
Old 03-15-2002 | 09:56 AM
1Boatnut's Avatar
US1 Fountainan and fstboater thanks for the help. I have seen the ads for the carbs and this is how this discussion started. It seems I can almost buy a new one for the same price or a little more than a used 1.I have e-mailed almost every ad and everyone was very helpful. But if I only can save $100.00 bucks or so I might as well buy new . Right? My biggest concern was as you stated USA 1 Fountain boats really dont need a choke and I did not want one. But I didnt want to **** rig stuff so it doesnt look good.
Thanks for the help
Paul
1Boatnut is offline
Old 03-15-2002 | 10:59 AM
Biggus's Avatar
I`d go with the 830, they have a much smoother transition from the primary to the secondarys and pretty much eliminate the lean spot just before the secondarys open. I`ve found them to work very well.
Kurt.
Biggus is offline
Old 03-15-2002 | 11:36 AM
1Boatnut's Avatar
Kurt,thanks for the reply. That is pretty much the way I am leaning and that is why I have been trying to get opinions from my O.S.O brothers and sisters.
Thanks Paul
1Boatnut is offline
Old 03-15-2002 | 12:57 PM
obnoxus's Avatar
Charter Member #1171
30 CFM !!!! sorry Paul,,,,, could't resist !!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
alecsammy
3
10-24-2008 05:53 PM
prosno
4
10-14-2007 09:20 PM
MACDAD260
9
05-26-2003 06:21 PM
Pantera24
1
05-20-2003 12:01 AM
sheikman1
7
12-13-2002 09:15 PM
