MEFI harness question >
Old 01-21-2009 | 02:21 PM
Default MEFI harness question
I am thinking about hooking up a MEFI computer to a multi-point fuel injection system on a regular small block Chevy. Are there standard wiring harnesses for this? For some reason I can't find any. This would be for a repower so hooking up to existing parts would not be an issue.
Thanks,
Eric
ebendrey is offline
Old 01-22-2009 | 02:18 AM
articfriends's Avatar
GM sells a mefi 4 computer w/harness including a 02 sensor for about 600$,you wouldn't use the 02 sensor on a boat but it's a pretty good deal,Smitty
articfriends is offline
Old 01-22-2009 | 09:33 AM
Smitty, do you have a part number for this?
bobl is offline
Old 01-22-2009 | 09:58 AM
Call this number ,,,,his name is Bill. He builts harnesses for all kinds of engines.
813 817 0577
DareDevil is offline
Old 01-22-2009 | 10:37 AM
12499116, That's the part number for the harness and computer. They can both be ordered seperately. If you've got a good GM dealer locally you should be able to pick it up for a little under $600 like Smitty said.. If that doesn't work out there are a few companies that make harnesses - Marine Power, Flagship, Kodiak.. etc. Let me know if I can be of any help.. Alex
HaxbySpeed is offline
Old 01-22-2009 | 11:41 AM
Try this http://gmperformancepartszone.com/me...=8_161_170_171
midwest272 is offline
Old 01-22-2009 | 01:58 PM
ii
hallj is offline
Old 01-22-2009 | 02:00 PM
Just by the whole works from MSD. It even comes with software to program it!
You can also buy the harness from them as well.
And yes, use the 02 sensor. Otherwise put a carburetor on it!
Jeff
hallj is offline
Old 01-23-2009 | 11:48 AM
Thanks for the information guys.
Another question. Do you use the MEFI computer to control the ignition timing curves? Does using the MEFI allow you to run a simpler distributor/ignition box or do you still end using the distributors with weights and pickups or the Crane box that handles the timing curves?
ebendrey is offline
Old 01-23-2009 | 01:18 PM
Mefi4 is a full engine management system. So yes it will control the spark advance as well as provide spark knock control.
It also has the capability of operating auxiliary components.
http://www.msdfuelinjection.com/mefi4.html
If you buy one from GM make sure it's "unlocked" so you can make changes to the calibration if so desired.
Jeff
hallj is offline
articfriends
41
09-20-2012 07:34 PM
bcarpman
Swap Shop
2
02-18-2009 08:29 AM
articfriends
Wanted
1
09-16-2008 08:31 PM
Smitty
22
10-18-2007 04:52 PM
Longblockbenny
1
09-30-2006 11:33 PM
