Fuel pumps
I am dumping my 7.4 MPI's and building 496's with edelbrock heads, eagle bottom ends, Crane 731/741, victor intakes, 950 carbs. Do I have a designated fuel pump for each motor or use a central pump for both? How do I know how much flow I need from the pump(s)?
Holley blue pumps should be enough for what you are building. Just make sure you use a large filter/water seperator and 1/2" lines. Also, make sure the pickup in the tank is large enough. I have seen so many boats with a little piece of crap plastic pickup. No matter how big a pump you put, if the pickup is to small, it won't work. Do not assume the pickup is big enough. Take it out and have a look. I build my own from SS tubing and fittings. Here is a pic of a factory one in a Donzi and the replacement that I built.
