pop up bow light >
pop up bow light
pop up bow light
Old 02-06-2009 | 10:57 AM
Default pop up bow light
Ok, my Baja 252 bow light is allways in the way of the anchor line, and it finally broke the plastic chrome cover off. thinkning about a pop up stainless one. 100-140 bucks
anyone put one on? howmuch do i have to cut on the fiberglass. work well? is there a better one to go with so the hole line up or anything?
mittens is offline
Old 02-06-2009 | 12:16 PM
Dock Holiday's Avatar
Charter Member #34
From what I can tell there is not much work required to install them. It appears that you just have to enlarge the hole a little which is pretty easy.
Call Mike Mayes at CP Performance and talk with him about them. He is a very good guy and will give you a good price.
Doc
Dock Holiday is offline
Old 02-06-2009 | 01:27 PM
Hey Pontiac:
Let us know how it goes. I looked at doing the same on my 25 Outlaw; but, there is a recess that the Perko light sits in. Looks like I'd have to do some fiberglass/gel coat work to make it fit.
Mike
Hot Tub is offline
Old 02-06-2009 | 02:27 PM
obnoxus's Avatar
Charter Member #1171
I have installed many here ,,,,,, the old ones required a template and saber saw,,,,, the new LED style mount in a circular hole drilled with a hole saw,,,, much easier !!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 02-06-2009 | 04:29 PM
Make sure you have enough clearance for the drain cup and you will also need to run a drain through the hull. or at down to the bilge. The light is not sealed and water will come through.
Padraig is offline
Old 02-06-2009 | 08:25 PM
Charter Member #34
Interesting that's good to know.
I guess if you have a drain in the anchor locker you could plumb it in to the existing line.
Old 02-06-2009 | 10:37 PM
Custom Interiors & More
That was the very reason that we went to the split nav. lights on the newer models. Seems like no matter what style single combo light you use, it will always be in the way as the boat moves in the wind.
The only problem with the pop-up light is finding someone sober enough to go to the nose of the boat at night....
XT
XT-Innovator is offline
Old 02-06-2009 | 10:51 PM
BDiggity's Avatar
XT
do they make ones w/ a small motor that will automatically raise up when u turn the switch on? thats what i am looking for to install on ours.
BDiggity is offline
Old 02-06-2009 | 11:18 PM
Accon Marine makes one with the sylinoid, but it will not fit the 252 without some fiberglass repairs. Cost, is also kind of high on that unit. I need to see the new LED style that was mentioned.
XT
Old 02-07-2009 | 08:55 AM
JasonSmith's Avatar
I have a cheap solution for you all.
After you set your anchor, take the line & loop it through the bow eye so you have a loop going through the bow eye. Take that loop up to the cleat & attach like the looped end of a dock line. Voila! You now have solved your bow light breakage problem.
JasonSmith is offline
