pressure relief valve location? >
Old 02-11-2009 | 09:16 AM
bcfountain's Avatar
Registered User
Default pressure relief valve location?
what is the correct location to install the t-fitting ?do i install before the pump,or after in the discharge side of the pump.i am using a cp performance system.
bcfountain is offline
Old 02-11-2009 | 02:51 PM
Are you talking about fresh water flush tee at a sea pump?
Pink Propellers is offline
Old 02-11-2009 | 05:05 PM
Ideally you would want it right after the oil cooler. Cools the oil, but doesn't send the water to the engine.
Griff is offline
Old 02-11-2009 | 11:21 PM
What Griff said.
AO31 is offline
MrCIG
37
06-19-2019 10:10 AM
SKRAMER
3
05-21-2008 12:08 PM
klaw
40
04-29-2008 09:31 PM
zt260
6
07-11-2006 06:24 AM
eliminatethis
3
06-20-2006 01:28 PM
