Counter-rotating engine??????
Starter,
gear drive the cam ( cam and dist/oil pump still need
to turn l/h),
water pump,
piston pin offset ( notch will face rear instead of the front
of the engine)
And I'm thinking there's something different with the front
and rear seals.
that's about all I can think of now.
to turn l/h),
water pump,
of the engine)
and rear seals.
ok so on a boat with older arnesons wouldnt it be easier to rig it so that one tranny is always running in reverse, then to build an engine that is counter-rotating??????
They would burn up in 3 min.
Trusst me i know !
