valves for hp 500 efi 2002 >
Old 02-16-2009 | 08:02 PM
Default valves for hp 500 efi 2002
doing top end, wondering what type of valves to replace stock with. Is it true efi motors should use a specific valve compaired to carb motors.
scopam is offline
Old 02-16-2009 | 09:07 PM
sleek1's Avatar
A lot of guys on here like Isky Tool Room valve springs. I'm having my springs done next week and am leaning toward Comp Honeycomb springs. I've heard they are great and the mechanic doing the work has had good outcomes with them. The carbed models you speak of are probably the HP500 models and they used the "old" Comp springs. As I understand it the 500 EFI engines use an upgraded Comp spring. There are a lot of threads about this subject, do a search.
sleek1 is offline
Old 02-16-2009 | 11:28 PM
You shouldn't need to replace the valves unless there is problem. Should just need a valve grind job.
BTW, the valve part numbers from carbed and efi 500's are the same.
Griff is offline
tcm07
10-03-2008 02:00 PM
Elite Marine
20
09-12-2008 05:28 PM
durbin3
3
02-12-2006 03:25 PM
gsmith9898
8
10-20-2005 02:25 PM
502 Magnum
5
12-06-2002 03:54 PM
