whats the best way to repair skegs? >
Old 02-23-2009 | 12:04 PM
Default whats the best way to repair skegs?
What do you do do to fix skegs that are broken off? Is this common? Will it affect the steering?
brian18330 is offline
Old 02-23-2009 | 12:09 PM
i have 1 of these also
jeff1000man is offline
Old 02-23-2009 | 12:11 PM
Any good marine repair shop can weld you up a new one.
laszlo01 is offline
Old 02-23-2009 | 01:35 PM
I asked back some time ago and I was told it should be around $250.00
nova26 is offline
Old 02-23-2009 | 04:03 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I bought replacement skegs from BAM approx 5 yrs ago. They are skegs that have just been cut off new drives right below the torpedo. I assume damaged drives. They make for gret replacement skegs since they are already the correct shape. I think they were $20 then. Mine was just damaged on the leading edge on 1 drive, and the bottom of the other, so I cut the replacement skegs to only that amount. Try to keep from welding any closer than needed. The heat can ruin your o rings in the prop shaft carrier. Put the carrier back in it if you do weld up high to help keep the torpedo from getting distorted from the heat.
US1 Fountain is offline
Old 02-23-2009 | 05:32 PM
RHC's Avatar
RHC
Call Ron Bender ,, JRmarine in Cleveland he is set up to repair your outdrives / sqeg's 216-390-1330
RHC
RHC is offline
nocigarette
Classic Offshore
15
01-20-2007 09:18 PM
DORaymond
12
02-23-2005 06:20 PM
SLINGSHOT
12-18-2003 07:52 AM
HOUSTONPROP
14
02-04-2003 06:01 PM
Offshore Roller
09-12-2002 10:59 AM
