01 272 top speed guess >
Old 03-05-2009 | 10:34 AM
Default 01 272 top speed guess
Hey guys my 01 272 currently has a 454 mag and i get around 64mph with a mirage 23p, my custom N/A 582 ci is almost completed(it been a way over budget project). The motor was built to be around 650hp, my question is whats your guess on my new MPH, obviously some prop tuning is going to have to happen, but i am hoping for at least mid 70's what do you guys think. Anyone built up a 272 lately?
Peter Lott is offline
Old 03-05-2009 | 10:50 AM
BAJA WILL's Avatar
Registered User
OK now you have the HP, 500HP gets that boat to 71-72, 650HP could get you to 80, I hope you have Hydrolic steering, if not please consider adding it.
OK 650HP I would start with a Bravo 26 then move to Bravo 28, or try a Hydro 26 and Hydro 27.
Plan on rpms around 5400 for best results, let us know how testing goes.
BAJA WILL is offline
Old 03-05-2009 | 03:22 PM
My 272 has 730hp 502sc I only got to run it once, but it went 80 gps turning a 30p bravo. With longer trim tabs and a labed prop my guess is that one would go about 85-87. I think that you should be able to get to 80+ with the right setup.
indywhsle is offline
Old 03-06-2009 | 08:46 AM
Mine is a Procharged 515". I doubt I have that much HP. I run a stern Jack and Hyd steering. I haven't run with my new set up but @4500 rpm without getting in the boost I ran 74( 30 P 4 blade) this year. I hope to see 90 in boost. I ran 86 the summer before on a 509" PC. Steering definitely needed because of chine walk.
kennyo is offline
Old 03-06-2009 | 03:54 PM
The chine walk is the reason that I only went 80. I was going to add the steering in the winter and then ended up buying a 29ol. I would love to see how fast it would go with steering, xbox, longer tabs, and 2" shorty lower.
Old 03-09-2009 | 02:56 AM
Once i get the motor put in i will plan on getting the steering done along with some longer trim tabs, i would have sold the boat but since boat prices have dropped so badly i figured i would just keep it and build it up. Thanks for all the input guys if you have any more let me know. I should be off to the dyno in the next couple of weeks
Old 03-09-2009 | 10:17 AM
Dock Holiday's Avatar
Charter Member #34
Nice set up Peter.
We had an 01 272 and loved it.
I would add the steering and tabs while the engine is out it will be much easier.
You should be in the 80's for sure.
Best of luck with it and keep us posted.
Doc
Dock Holiday is offline
Old 07-24-2009 | 06:29 PM
I'm interested. Did you get it going?
tjtyler is offline
Old 07-24-2009 | 09:20 PM
obnoxus's Avatar
Charter Member #1171
I had a 272 with a blueprinted bottom ( almost a must at that speed ).
Im gonna guess 83-85,,,, lil more if you have the hook taken out and your edge sharpened
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 07-25-2009 | 05:51 PM
I hope everything went OK. I am at 70 without external sterring 80 is pushing it to the limit.
jeffswav is offline
Rambunctious
07-22-2019 12:09 PM
flatout
09-12-2005 02:12 PM
Formula Outlaw
07-23-2004 07:18 AM
bulabula
03-26-2003 01:16 PM
pullmytrigger
02-16-2002 06:53 PM
