Engine Builder Beware
Old 03-08-2009 | 07:29 PM
Default Engine Builder Beware
A good screwing from another engine builder JTM machine from Ohio. Had to get into a fresh engine that was done by them and dyno'ed that was leaking oil out of it on the stand. I found loose valve cover bolts, a 1/2 a$$ install of the oil cooler and lines (all were loose) I also found three different brands of head bolts installed on the motor what a magnificent piece of workmanship. I wouln't trust them with a leaf blower motor better yet one for my model airplane.
Sweet Nmocean is offline
Old 03-09-2009 | 12:01 AM
Full Force's Avatar
That sucks, glad I do my own assembly, then at least if it is wrong... my fault!
Full Force is offline
Old 03-09-2009 | 02:58 PM
The way the economy is these people should be kissing a$$ like there is no tomorrow, with workmanship like this hopefully there won't be.
Old 03-09-2009 | 03:02 PM
Where are they located?
NEVERSATISFIED is offline
Old 03-09-2009 | 04:18 PM
Canton/Akron area
Old 03-09-2009 | 06:21 PM
That sucks we just met them in fla. a couple of weeks ago at the poker run seemed like good guys. I was hoping to have found another good engine builder.
Did you contact them and what was there explanation for this. What did you find inside?
89scarabIII is offline
Old 03-09-2009 | 08:43 PM
What we found was at least three different brands of head bolts installed "under the valve covers", the oil lines that go to the cooler were finger tight, we changed everything over to aeroquip lines, we found the valve cover bolts by the exhaust finger tight, the oil adapter on the bottom of the engine had no o-ring on the center bolt leaking oil. Is that what you would call a quality build?
Old 03-09-2009 | 08:48 PM
I feel your pain Bro
Old 03-10-2009 | 12:10 AM
There's a forum for these posts. Did you ask for your money back?
Hot Knots is offline
Old 03-10-2009 | 05:06 AM
See.. That is Justed F*cked up.
Most never cry about the engine bill, But when you see what "Some" do with the engine you want to choke the living P*ss out of them. ..Do you think the engine builder thought you may NEVER take the valve cover off??
Some guys just don't have any pride in their work!!
Sorry for you Loss !!!!!!!!!!
mmareno is offline
