Trim Tabs
Old 03-11-2009 | 08:47 PM
Default Trim Tabs
I what To upgrade my the engine(305,260hp) but it already is borderline chine walking as it is. It doesnt have tabs, but i would like to put some on. What size and brand should I go with?
outlaw02 is offline
Old 03-12-2009 | 08:11 AM
It all depends on your budget and how much time/effort you want to put forth on installation. As I mentioned in your other thread, I was happy with the results I got from Lenco tabs on my 20' Baja. Danas or small k-planes would be great, but expensive and much more difficult to install. There's very little free space on the dash on that boat so the Lenco indicator pad (switches and tab indicator all in one) helps there too.
This thread may help in your decision: http://teambajamarine.com/forum/show...ight=trim+tabs
emilsr is offline
Old 03-12-2009 | 12:19 PM
KEPP's Avatar
Only the Best Will Do!
Here's a couple of great options to consider that I believe are a better quality product.
http://www.keitheickert.com/detail.aspx?ID=10184
http://www.keitheickert.com/detail.aspx?ID=9508
KEPP is offline
Old 03-12-2009 | 12:48 PM
I have a set of 280's that are take offs. Look brand new except for a couple paint chips from being moved around in the shop so much. Have pumps, lines, everything you need except the switches at the dash. Great upgrade for that boat.
PM me if interested.
Jeff
jeff1000man is offline
Old 03-12-2009 | 01:58 PM
What about location. Ive heard on small boats to put them as close to the drive as possible. Its not inb the water by much
outlaw02 is offline
Old 03-12-2009 | 04:47 PM
ChristianGott's Avatar
where's george yourick (sp?) when you need him...small boats going 100 were his specialty...
....i'd just go with bennet's, but not mounted parallel to the bottom, i'd mount 'em straight across, so the outer edge is the first thing to hit the h2o...heck, call reggie, it's his company now!
c
ChristianGott is offline
26sonic
Sonic
8
06-23-2009 09:14 PM
dloftis
Baja
8
03-12-2009 08:08 AM
Monaco20
11-18-2008 12:39 PM
fastestbowtie
2
09-12-2005 08:45 PM
paxtonsc
08-08-2005 03:38 PM
