Ordered my new trailer!!!
Old 03-12-2009 | 01:15 PM
noyzee's Avatar
had to get something to tow my new 26 checkmate. so i did some searching, i ended up with an all alum bunk style load rite, 15" mag wheels, led lights, guids, disc brakes ect etc etc.
cant wait to get it. need to drop off the cash today.
noyzee is offline
Old 03-12-2009 | 02:31 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If you can upgrade to 16" wheels/tires do so.
1. You can find 16" tires almost anywhere in an emergency.
2. 16" tires you can find in higher weight rating than 15".
3. 16" tires means more tire and more revolutions per mile which means the tires will run cooler.
4. 16" tires gets your trailer higher off the ground which is better for steep ramps.
5. 16" tires means you can run LT truck tires which many recommend nowadays over ST (special trailer) tires. I recommend the Firestone Trans Force tire.
DON'T SKIMP THE TRAILER!
Sydwayz is offline
Old 03-12-2009 | 02:59 PM
lucky strike's Avatar
Go with the 16" if you can swing it.
lucky strike is offline
Old 03-12-2009 | 03:20 PM
How much does a 26 checkmate weigh? You guys gonna tell him he should've gone with a triple axle too?
Congrats on the trailer purchase. Other than the discs and pads, spray every non-AL & non-stainless piece with a corrosion blocker. The effort you make on that will keep it looking good for years.
handfulz28 is offline
Old 03-12-2009 | 03:24 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I'd put tank tracks on it.
Sydwayz is offline
Old 03-12-2009 | 03:29 PM
fantastixvoyage's Avatar
If I had seen this earlier I would have...I have a triple axle that is a touch small for my 29'.
fantastixvoyage is offline
Old 03-12-2009 | 08:18 PM
rchevelle71's Avatar
did you check out EZ loader?? Aluminum bunks are sweet.
rchevelle71 is offline
Old 03-13-2009 | 12:37 AM
Z06
Congratulations on the new trailer, it's always fun to order a new one.
Z06 is offline
Old 03-13-2009 | 05:13 PM
noyzee's Avatar
it came in today, i picked it up already. came in very fast. i will double check, i got the upgraded wheel package but i will have to see if its 16's or not. it looks real nice tho, dimond plate fenders etc. i like it. im going to polish and clean it up tomorrow, and corrosion block everything. also going to take the stupid crap wire connectors apart and solder and shrink wrap everything.
i will try to get pics tomorrow.
it should be fine for me as i might travle 20 miles with the boat every 2-4 weeks. and maybe once or twice trailer to a poker run within 100 miles of me. i keep the boat in the water for 2-4 weeks at a time in my slip, so the trailer doesnt need to be to over kill. after seeing the one i got, i probably could have got away with allot less. lol, but it looks good
noyzee is offline
JIMKID Motorsports
Skater
14
12-22-2007 09:16 AM
bobl
Nordic
3
09-26-2007 05:26 PM
krakmeup
Superboat
192
10-15-2004 07:39 PM
WETTE VETTE
10-21-2002 04:32 PM
