Fueltank return line >
Old 03-17-2009 | 08:39 AM
Secretformula's Avatar
Default Fueltank return line
What is the easiest way to add two return ports to a glassed in gastank? I understand this is the way to fix a vaporlock problem on the 502 efi engines.
Secretformula is offline
Old 03-17-2009 | 10:22 AM
bcfountain's Avatar
Registered User
Default location
i think the easest way would be to buy a fitting that cpperformance sells that goes into the rubber hose that is your gas fill.it has a tee fitting and you can return the fuel that way.i have heard sooo many ways to fix the vst injection that i cannot rember them all.i have a 94 fountain w/the same problem,rough idle,vapor locks sometime,etc,etc.let me know if it works,i am about ready to can the injection in favor or a carb.just dont like the consumpton of a carb vers injection.good luck.
bcfountain is offline
Old 03-17-2009 | 11:36 AM
Dock Holiday's Avatar
Charter Member #34
Originally Posted by bcfountain
i think the easest way would be to buy a fitting that cpperformance sells that goes into the rubber hose that is your gas fill.it has a tee fitting and you can return the fuel that way..
+1
Call Mike at CP and he will fix you up.
Dock Holiday is offline
Old 03-17-2009 | 12:15 PM
CPPerformance's Avatar
Hey Secretformula, we do offer this fuel return adapter that should make your project just a tad easier. You can click on the picture for more information. Goodluck!
CPPerformance is offline
Harlequin
2
02-20-2009 11:01 AM
Noise Pollution
14
04-17-2008 10:49 PM
Elite Marine
Pantera
6
12-26-2006 01:08 PM
502SS
14
05-16-2002 03:59 PM
strapman
4
01-11-2002 08:58 AM
