prop play
one of my Bravo props has play in it,I thought it was the hub so I replaced it,still have about 1/2 inch play back and forth,I can see the prop shaft and nut not moving .
possiable bad prop?
possiable bad prop?
Hey Tom....was thinking....could it be that the insides of the prop itself is damaged? worn out so to speak??
-Wally
-Wally
thanks for the reply,
the boat has twins and both thrust washers look the same,cant tell if there worn,
does anybody have a picture of a prop set up with the hardware for a 2003 bravo 1 they can post?
not sure if I'm missing anything
I also wonder if the insert is Delrin? If it is it could be cracked. If not, either stainless insert could be missing the snubber strips and there could be some play. However, 1/2" sounds extreme.
B
B
[email protected]
[email protected]
feels like the nut is not tight,but it is
I was told to crind the brass insert down a little because sometimes it bottoms out against the hub and it will cause the free play I was having,after crinding it down I installed the prop and it felt tight,took the boat for a ride and rechecked the prop,still nice and tight,
thanks for the replys
There was a issue with the delsin fwd. bushing size. Your adjusment is a good fix.
B
B
[email protected]
[email protected]
Fountain38
07-01-2002 10:19 PM
