TRS - engine R & R help.... >
Old 03-26-2009 | 08:37 PM
Default TRS - engine R & R help....
I pulled my engines out this past winter without pulling my drives. This went quick and easy. The question I have though is what about putting the engines back in. The drive shafts kind of do the weeble wable thing and I am not sure how you keep the alignment when lowering and moving the engines/trans back to place.
The last time I did this (years ago) I had pulled the drives before pulling the engines. I could still pull them and reinstall them however I'm looking for an easier way out . I can't see any way to hold the shafts in place during or when getting close to engine placement.
Thanks for any help.
John
getrdunn is offline
Old 03-26-2009 | 08:41 PM
jeff32's Avatar
my guess is you have to take them off or, maybe turn the prop so the spline slips in your tranny... but I never did what you've done.
jeff32 is offline
Old 03-26-2009 | 08:42 PM
Biggus's Avatar
On my TG, I never remove the drives when swapping motors.
When you're lowering the motor in, just feed the input shaft into the trans and have someone tun the prop slowly. Usually less than a turn of the prop and the shaft engages into the spline. I've never had even the slightest issue.
Kurt
Biggus is offline
Old 03-26-2009 | 08:49 PM
that might work. sounds like a job for the b-i-otch. maybe she can hadle that job better than putting fuel in the caddy today. did i forget to mention diesel fuel into a gasoline engine. Ya, that was a nice phone call late this afternoon right after i backed over my sons ATV with my Ram 3/4 ton.
i felt like throwing myself in the outdoor wood boiler and calling it a day.
John
getrdunn is offline
Old 03-26-2009 | 08:51 PM
thank you both for the help. as noted i'm sure you see why i'm not thinking clearly at the moment.
getrdunn is offline
Old 03-26-2009 | 08:58 PM
spazboz's Avatar
I always pull the drives and check alignment. I know people who and have never had any issue's. For me personally I just like to know that its all running true.
spazboz is offline
Old 03-26-2009 | 09:15 PM
Default Funny
John
This isn't a boat but it's a must see. http://www.youtube.com/watch?v=hKb4UQxTbRw&NR=1
getrdunn is offline
Old 03-27-2009 | 07:22 AM
Biggus's Avatar
You'd be busy trying to install on a Bravo boat.
TRS has no gimbal bearing, just a trans tailstock bearing that's fixed.
The TRS has a rather long input shaft so it's not too bad getting it to line up. Here's a pic of a BW fitted with a TRS tailstock.
Biggus is offline
Old 03-27-2009 | 08:41 AM
What biggus says is how i do it. While lowering, just feed the input shaft into the tailstock, and once its in, have someone turn the propshaft while you put a little pressure pushing the motor/trans assembly towards the transom, it should slide right in.
MILD THUNDER is offline
Old 03-27-2009 | 09:22 AM
Rookie's Avatar
Not to Hi-jack this thread, but the bearing that you are talking about is it serviceable without pulling the tranny? I thought I heard people replacing the gimble bearing on a TRS boat, this must be the bearing they are replacing???
I thought I read where you have to cut something out to access this.
Rookie is offline
