Batteries and electical question. >
Old 03-28-2009 | 09:02 AM
Default Batteries and electical question.
Can anyone tell me which battery powers the cabin electronics and which battery is 1 and 2 on the switches. Should I have two deep cycles or should one of them be just a starting battery.
89scarabIII is offline
Old 03-28-2009 | 09:07 AM
blownincome's Avatar
Batt 1 is the starting battery and 2 is the House (but in Fountain land that can change) but 9 out of 10 are set up that way
blownincome is offline
Old 03-28-2009 | 09:23 AM
I have two switches and two bateries. Which is 1 port or starboard?
Old 03-28-2009 | 02:49 PM
Yamaha 225's Avatar
Yes, can someone explain this in detail? It does not explain itself....
My impression is that each switch supply power to the corresponding engine.
(with 2 switches, 2 engines, 2 batteries)
Starb. switch gives power to Cabin power panel
Port switch gives power to tabs, trim.
If I remember right, this is how my boat is set up.
Correct me if I am wrong!! I get a bit confused some times when switching on.
A good rule is to let one engine run on battery 1, and the other on batteri 2. When stationary, and with the stereo, interior lights etc. on for a long time, the other battery can start the both engines when switched to the 1+2 position. Am I right here?
Yamaha 225 is offline
Old 03-30-2009 | 01:09 PM
Bob , so how is mine ? battery port side for port engine and starbord battery for starbord engine ? do you leave both switchs on #1 ????
tim brown is offline
Old 03-30-2009 | 04:08 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
P switch to #2= P battery to the P motor,
S switch to #1= S battery to the S motor.
Easy way to remember, each switch points to the side of the boat that it is on. LLL, RRR (switch, battery, motor)
With both switches set to either 1 or 2, both motors will be starting off/charging the same battery. Not best to run them set to same position. And don't run both iswitches in the BOTH position.
US1 Fountain is offline
Old 03-30-2009 | 07:56 PM
I'm am confused. have one switch to 1 and the other to 2 . is that corect ?
Old 03-30-2009 | 08:31 PM
Ginger or Mary Ann?
Yes.
Pos 1 is for the S battery
Pos 2 is for the P battery
This applies to both switches.
Old 03-30-2009 | 08:37 PM
Ginger or Mary Ann?
enjoy
Old 03-31-2009 | 09:51 AM
BeakBoater35's Avatar
Why not run the switch in "BOTH"?
[QUOTE=US1 And don't run both iswitches in the BOTH position.[/QUOTE]
BeakBoater35 is offline
