Which outdrive gears to go with? >
Old 03-28-2009 | 08:33 PM
Default Which outdrive gears to go with?
Hey guys I just bought an 1989 wellcraft eclipse 232. It came with a 350 that didnt run so I just bought a 1996 454 magnum for it. Now i have the outdrive to worry about. Right now i have the option of buying a bravo 1 outdrive with a 1.36 gear ratio or buying a bravo 1 outdrive with a 1.5 gear ratio. I am really confused on which drive to go with...both are relatively the same price, i just have no clue which one to go with. I dont really understand how the gear ratios differ and what the the pros and cons of each gear ratio are.
You guys have any ideas? Thank you for any help,
Chuck
Eclipse232 is offline
Old 03-28-2009 | 09:10 PM
1:36 is a lot of gear for a stock 454. It "could" work if you have a small enough prop for it, but...... the ideal setup would be a 1:50 with the correct prop.
Darrell.
DMOORE is offline
Old 03-28-2009 | 09:37 PM
Darrell.
x2 on the 1: 50 that would have been more of a standerd set up if from new.
Boat Tech is offline
Old 03-29-2009 | 01:29 AM
Definately the 1.50. You'll probably still only turn a 23" prop.
Griff is offline
Old 03-29-2009 | 03:26 AM
Vinny P's Avatar
I hate the winter!!
I agree. A 1.36 gear should only be used if you run out of available props for a 1.50.
Vinny P is offline
Old 03-29-2009 | 12:58 PM
Gotcha. Thank you guys!
Old 03-29-2009 | 01:06 PM
Then that leaves the prop. Do you guys know what pitch i shoud go with? 23 pitch or a 21 pitch 3 blade?
Old 03-30-2009 | 02:01 AM
I'm about 90% sure you'll need a 23" Mirage Plus. If you want better cruise and holeshot go with a 22 Bravo 4 blade and loose 2 mph on the top end.
Griff is offline
Old 03-30-2009 | 06:56 AM
Thank You Guys Very Much!
Old 03-31-2009 | 04:37 PM
MarkDonzi's Avatar
I have a 23 pitch mirage prop if you are interested.
MarkDonzi is offline
boatnt
08-23-2021 12:39 PM
articfriends
193
06-26-2010 09:10 AM
Hot Boat
Drives and Lower Units
12
12-22-2007 12:27 AM
articfriends
16
07-25-2006 07:17 PM
Missmymoney
02-17-2002 06:20 PM
