Painting the hull?
Old 03-30-2009 | 11:03 AM
czy40p's Avatar
Default Painting the hull?
I have all the fillers, primers and paints picked, but I was wondering about the technique to spray the bottom. The boat is currently off the trailer, on blocks and boat stands and it is all sitting on concrete. Can I safely tip the whole boat enough to one side to do it one side at a time? Anybody done this or have any good ideas. It was stable on just the two rear stands as I was pulling the boat off the trailer, but not sure, about how well the front two would do. It is the hull of an 89 Scarab 28' Excel, (Engine and transom are out)
Jim
czy40p is offline
Old 03-30-2009 | 09:46 PM
Audiofn's Avatar
Charter Member #232
I put mine up on my trim tabs in the back and then a block up towards the bow. Just had a small blend spot to do later by moving the block.
Put your best foot forward!
Audiofn is offline
Old 03-30-2009 | 11:00 PM
Jim
Yes,,u should be fine. Just dont scratch the new paint by doing the second side !!
DareDevil is offline
Old 03-31-2009 | 05:49 AM
czy40p's Avatar
Smile
Thanks guys
czy40p is offline
Old 04-03-2009 | 09:55 PM
monstaaa's Avatar
if you do 1 side at a time, there will be a tape or blend line right down the middle of the boat. may not work out so well. may also increase the chances of peeling.
best way would be to flip boat onto deck. youll also be able to sand out an imperfections in the bottom much more accurately.
monstaaa is offline
sonic35ss
Sonic
1
05-27-2008 07:12 PM
russ
0
07-21-2005 04:35 PM
1stfntn
6
03-27-2005 11:31 AM
bajah2x105
Baja
8
06-17-2002 04:45 PM
Adivanman
13
05-08-2002 11:35 PM
