konrad/trs
Old 04-06-2009 | 11:10 AM
Default konrad/trs
i have been told that konrads will bolt up to a trs gimble, does anybody know for sure?
5050 is offline
Old 04-06-2009 | 11:21 AM
bor's Avatar
bor
you can find all info on there website ,oir call them
http://www.konradmarine.com/index.cfm?optionid=8139
bor is offline
Old 04-06-2009 | 11:26 AM
cigrocket's Avatar
Yes, Konrad Conversion come with a different Helmet becasue of the oiling system. So all you have to do is remove the Hinge Pins, replace the helmet. Attatch the drive. You also need to add a new resivoir that is larger capacity then the Trs. Its simple, can be done in a couple of hours or less with a few tools.
If you have any further questions PM Biggus, he is the Rep.
The Konrads come with a bunch of manuals and installation manuals. Its very easy
cigrocket is offline
Old 04-06-2009 | 11:33 AM
Biggus's Avatar
Here's the manual for the 1/2 conversion.
http://shared.buildmeaportal.com/web...ID9650DOC1.pdf
And the full conversion (including gimbal assembly)
http://shared.buildmeaportal.com/web...ID9650DOC2.pdf
Feel free to call me direct for more info.
Kurt 715-410-0735
[email protected]
Biggus is offline
Old 04-06-2009 | 12:44 PM
BDiggity's Avatar
& i think biggus has a refirb pair for sale that is very reasonable.
BDiggity is offline
Old 04-06-2009 | 04:02 PM
Elite Marine's Avatar
And I have the Ace for sale, which I could break up with the gimble, drive and trans!!
Elite Marine is offline
Old 04-07-2009 | 05:08 AM
Biggus's Avatar
Kirk, your Konrad ACE package is certainly priced very aggressively but it's not interchangable with the unit specifically designed as a retrofit for the TRS.
The Konrad 540 PRS (TRS replacement) is fitted with an input shaft 3" longer than the ACE unit as the TRS transmissions have a tailstock 3" longer than the ACE trans.
Feel free to call for more info.
Kurt 715-410-0735
[email protected]
Biggus is offline
