Best Oil choice for supercharged 454 without thermostat >
Old 05-05-2009 | 08:20 AM
Default Best Oil choice for supercharged 454 without thermostat
Can someone help me select the oil I should be using for best protection and performance? I have a 2330 Chaparral with a 454 MPI that runs a 7lb boost from Procharger. I should mention I do not run a thermostat based on prochargers recommendation. My engine really never gets that warms so that has me confused as to the proper oil weight I should be using. Any help would be greatly appreciated.
lilwigs is offline
Old 05-05-2009 | 09:10 AM
Biggus's Avatar
I've tried them all and found Mobil 1 V-Twin (20-50) the best for my blower motor application.
Biggus is offline
Old 05-05-2009 | 09:21 AM
Does not running a thermostatat impact this at all? Procharger says just use the standard recommended oil, but I doubt my engine ever gets above 150? Thanks for the information by the way. Oh...so you run a thermostat in your application and what are your running?
lilwigs is offline
Old 05-05-2009 | 09:24 AM
Just because your engine temp isin't getting warm doesen't mean your oil temp isin't HOT
Westcoast is offline
Old 05-05-2009 | 09:34 AM
n the other hand running the block at 150 isn't doing anything in there any good either and will cause vastly accelerated wear. your choice , of course, and proper oil temp is crucial in all respects... too cold is just as bad as too hot... i suggest you monitor both. i'm sure the pro charger guys don't want detonation from high combustion chamber temps but if the piston/bore clearences never get where they need to be then you are almost as bad off. you'll end up w/ fuel contaminated oil and that will be that.
stevesxm is offline
Old 05-05-2009 | 11:27 AM
So would this group recomment putting in a 120 thermostat? I should admit I don't know a lot about engines, but do know the block needs to be warm enough for proper ignition etc. I also have a transom cooler which takes water after the inner cooler (and engine block?) and puts it on the lower unit. Is this hooked up correctly? Seems like pretty strange to put heated water on the transom?
lilwigs is offline
Old 05-05-2009 | 11:39 AM
well... recognizing that i am of the minority opinion on this forum in this regard, my reccomedation would be a 165 or there abouts. i think 150 in the block is too cold.
stevesxm is offline
Old 05-05-2009 | 12:31 PM
Mobil 1 Vtwin is tough to beat although Amsoil's new dominator racing oils look nice.
MikeStaz is offline
Old 05-05-2009 | 07:50 PM
Oil should be at least 180*F. I would also think your block could stand more heat also.
Ken
Mobil V-Twin .....tough to beat.
minxguy is offline
Old 05-06-2009 | 08:56 AM
PatriYacht's Avatar
Assuming that your engine was built with the proper cylinder to wall clearences, you don't want to run a a thermostat more than 120 deg. Merc. used 140 degree thermostats for years on all of their carb engines. Any hotter than that will just promote detonation. Arizona Speed and Marine sells a 120 degree thermostat for use in their supercharged engines. It's a simple step to keep cylinder head temps low to help prevent detonation. As long as your oil temp is in the 200-240 dgree range, you're all set.
As far as what oil, that depends on what clearences were built into the engine and what oil temp and pressure you're running. If your oil tends to the cold side, I would use a muti grade synthetic like Mobil 1 15-50. The Mobil 1 20-50 would work better on a hotter running engine, it's noticably thicker.
PatriYacht is offline
