Mercury Vessel View ??
79-898277K02 Standard Vessel View
This one goes for bout $1200. I'm sure the race version is probably more. I think the Race version of this product is the coolest thing in boating right now. Just my opinion. If setup properly and if it works like they say, it actually works as a slip indicator much like the one from Livorsi but way better. It's tied to drives and tab settings and overall helps maximize the hull/power. Wish I could afford a boat that already has it installed and dialed!!
Of course, it does way more than just this. It's way nice in theory.
Now can anyone tell me how to reset "fuel used" in this SmartCraft Monitor?
Been on the phone with Merc 3 times now. They trip, they fall, and then don't call me back.
I have a feeling that it's not re-setable. Is that a word?
Probably just a data field that is non edited.
Here's what it does. Screens and layout are totally customizable.
Vessel Information:
Boat Speed (from Pitot, Paddle Wheel, or GPS)
Water Depth
Fuel Tank Levels
Air Temperature
Sea Temperature
Port, Starboard, and Center Trim Tab Position
Outboard/Drive Trim Position
Inches Traveled Per Engine Revolution
Remote Oil Tank Levels
Boat Fresh Water Tank Levels
Boat Waste Water Tank Levels
Total Vessel Fuel Flow
Range
Fuel Used
Average Fuel Mileage (0.01 resolution)
Instant Fuel Mileage (0.01 resolution)
Clock/Time
Peak Speed
GPS — Bearing to Waypoint
— Speed Over Ground
— Course Over Ground
— Distance to Waypoint
— Time to Waypoint (calculated from GPS data)
— Fuel to Waypoint (calculated from GPS data)
— Dedicated hi-speed GPS antenna
Engine Data:
Engine RPM
Engine Water Press ure
Engine Coolant Temperature
Engine Oil Press ure
Engine Oil Temperature
Engine Fuel Flow
Battery Voltage
Engine Boost Pressure
Engine Fuel Pressure
Fuel Pressure Delta (regulated fuel pressure)
Vessel Information:
Water Depth
Fuel Tank Levels
Air Temperature
Sea Temperature
Range
Fuel Used
Clock/Time
Peak Speed
— Speed Over Ground
Engine Data:
Engine RPM
Engine Fuel Flow
Battery Voltage
it is nice though. mine will not reset regardless of what i do....
