Help 1996 7.4 mpi efi bogs off the line >
Old 05-12-2009 | 11:40 AM
Default Help 1996 7.4 mpi efi bogs off the line
has all new cap rotor plugs wires and still bogs when i hit the throttle it bogs can anyone help me with this , thanks james
jimmie is offline
Old 05-12-2009 | 02:22 PM
Default carb
has the carb been cleaned or rebuilt recently??? may want to look there
21eagle is offline
Old 05-12-2009 | 03:19 PM
I'm with 21, it sounds like an accelerator pump. Remove the air cleaner and check that fuel is coming out of the squirters on top.
brwn234 is offline
Old 05-12-2009 | 03:36 PM
Could be water in the gas (ethanol)?????????
TexomaPowerboater is offline
Old 05-12-2009 | 03:38 PM
MPI check fuel rail pressure
Tax_man is offline
Old 05-12-2009 | 05:05 PM
Default how to check fuel rail pressure ?
how can i check the pressure pz
jimmie is offline
Old 05-12-2009 | 05:16 PM
after it bogs,,,,does it clear up and run good on top end,,,or does it keep bogding down all thur the rpm range
TWIN-SPINS is offline
Old 05-13-2009 | 04:13 PM
Default It Clears Up After It Bogs
yes it runs fine after it bogs
jimmie is offline
Old 05-13-2009 | 05:39 PM
check all vacuum hoses for leaks,,,,other possible thing to look into,,,,map sensor,,,,tps sensor,,,,fuel pressure regulator
