Carb guys in here....
Alright, so I am freshining up my 800cfm Holleys and I accidentally kinda broke the overflow tube
on the primary side. How do you get those things outta there to replace them? Or am I skee-rewed? Also, is that something I can get anywhere?
Can you get a pair of pliers on what is left? Pliers and maybe some heat from a small propane torch should work. Twist and pull...if it has to be drilled out, you might consider going to a machine shop for help. You can likely find the part # on Holley's website and then try Jegs, Summit or Google.
ARE YOU F**KING KIDDING ME ? A TORCH ON A CARB ? DUDE...TAKE YOUR CARB ADVICE ELSEWHERE. WOW !! The tubes are pressed in. Try and work them out the best you can, or maybe an easy out gently. Id call Summit Racing, or Holley directly. Take your time..you'll get it out.
Call me tomorrow so we can figure out whats up. I have to hit work for an hour or 2 and try to get the grass cut but should be free the rest of the day
That'll work. I'll hit you up.
Unless you have any clue how repairs are made by people that know what they are doing, DUDE... keep your F*****G coments to your self, and feel free to put the easy-out in your carb.
