Cracked exhaust manifold?
Is there a way to determine if an exhaust manifold is cracked? Or do you simply eliminate all other causes (cracked head, bad head gasket, cracked block) and assume?
Wondering if a local marine shop has a way to determine if I bring it in?
Take it off and pressure check it ,,u can do taht at your house !!
So simply fill the water passages with CRC? What about using water itself to check instead of CRC?
