Dart block lifter question
I have a new motor going together and the foundation is a new dart 10.2 deck block. the problem is that I have comp cams hydraulic roller lifers with the vertical tie bar and it bottoms out on the lifter block. anyone have this problem. I have another set of isky lifters and they do the same thing. does the block need machined in this area or does someone know of a set of hr lifters that will work
You need something like this. They are .300 taller than stock.
http://store.summitracing.com/partde...6&autoview=sku
I have a friend who ran short lifters in a Dart block. One of the link bars broke off and caused some significant damage.
Eddie
I have comp 7141 and 7131 pushrods. I ordered the .300" lifters. are these pushrods going to be too long since they were in my other motor? it was a 10.2" bowtie block and it had the standard height lifters. I know have a 10.2 deck dart block with .300" lifters. the tech guy at comp said that the pushrod length should be the same as the only difference is the actual body of the lifter and the plunger is the same height?????????/ I guess I will get my trust pushrod measuring tool out tomorrow. damn I am tired of problems.
You won't know until you mock it up and check the rocker geometry. Just have to check them and see.
well I went from comp lifters to comp .300 taller lifters so i was assuming that my pushrods would be too long................... thats what happens when you assume. the new lifters have a taller body but the plunger is farther down inside the lifter so the pushrods were actually too short.
