28 Speeds
Old 06-11-2009 | 07:33 PM
rlj676's Avatar
Default 28 Speeds
What does a 28 run with the various engines? I've tried searching and haven't found much.
For example,
A single 500 hp vs 502 twins, etc.
What's it take to run 70, 80 in a single or twins.
Thanks.
rlj676 is offline
Old 06-11-2009 | 08:42 PM
I have a 1998 28 that had a single 509 blown 725 hp bravo one 1.5 spinning a herring 5 blade
top out at 5400rpm 87mph.
The blown motor has been replaced by a new 502 with similar specs a hp500 with a litlle bigger cam, approx. 550hp.
We have not splashed it but beleive that it should run approx 75-78 and get great fuel mileage
I have been a 28 with twins and it did not ride as well and topped out at 78....stock 502 mpi....too much wait for the length and the drives ride way too high.
this of course is with i/o
MACTIME is offline
Old 06-11-2009 | 08:46 PM
My 28 with twin 300 promax's runs 80
cowisl is online now
Old 06-12-2009 | 02:40 PM
rlj676's Avatar
Thanks guys.
So it seems that 500 hp will break 70?
Also, twin big blocks are too rear-heavy then and a big single is best (or outoards if that's your deal)?
rlj676 is offline
Old 06-14-2009 | 12:30 PM
Originally Posted by rlj676
Thanks guys.
I would say a nice 650 HP BB ,,should get u in the mid 80's easy.
The one that raced back in 98ish did almost 95 !!!
DareDevil is offline
Old 06-15-2009 | 07:40 PM
rlj676's Avatar
That sounds pretty good.
So nobody knows though what a single HP500 will run?
rlj676 is offline
Old 06-15-2009 | 10:24 PM
U should be in the mid 80's for shure !!!!
Old 06-16-2009 | 04:25 PM
rlj676's Avatar
Sounds optimistic....but I like it.
rlj676 is offline
Old 06-16-2009 | 06:30 PM
It should do it ,,,with the right prop and maybe a shortry,,or extension box !!! 80-85,,the boat is not that heavy.
My old 33 was ~ 6400 # with twin BB and Imco's,fully loaded
Old 06-16-2009 | 06:42 PM
rlj676's Avatar
If I get this boat I'm looking at it has no external hydraulic steering, so I might go for an exension box (they can have internal hyd seering right?). Otherwise I agree it shouldn't be too heavy at all, pretty light on the amenities.
rlj676 is offline
