Alternator Upgrade
it depends where your other wires go to. some alternators have a wire that goes directly to the coil, if that is the case you won't run. it will start from the 12 volts from the switch but die as soon as your out of the start position. Fran
Exa eagle I have not seen that problem before as that wire can not stay hot all the time? If it did how would the engine shut off? Interesting.
Anyhow you should put the ground wire to the alternator there will be a post for it. The other wires wrap up well with tape and tape them back in case you swap back again. If you have any questions just ask
audiofn
on that particular setup, you turn the key off and it grounded the coil to kill the ignition. the 12 volts to start was from the battery via the start position on the key, the voltage to run came from the alternator.
