Starter Question ..... >
Old 04-02-2002 | 08:31 AM
RickA
Unhappy Starter Question .....
I just finished installing a new 502 Mag in my boat and when I went to test start it, all I got was the familiar dead battery clicking from the starter. So I went out and bought a new 875 CCA marine starting battery, installed it and same thing....more clicking. Grrrrr !!!
Checked all the connection to the starter, battery and also check the ground on the back of the engine.....still only clicking.
Haven't tried a slight whack on the starter solenoid, but that could be next.
Any suggestions before I rip the started out ?
Rick
Old 04-02-2002 | 10:35 AM
CheckmateF1's Avatar
Charter Member #355
There is a starter solenoid on the back of the motor where you Merc harness plugs in. It could be bad. Try bypassing it with a jumper wire or screw driver. If the motor cranks, get a new solenoid.
http://www.mercruiserparts.com/Show_...S+%28ENGINE%29
Copy and paste this link. The solenoid is #5 in this diagram
Next step would be double check all battery cables for corrosion and tight connections, then check the starter itself.
Good Luck, Eric
CheckmateF1 is offline
Old 04-02-2002 | 10:49 AM
RickA
Thank's for the info Eric, I'll give the solenoid a try.
Rick
Old 04-02-2002 | 11:30 AM
You should check to see if you have water or oil in the cyl
Dixie Doug is offline
Old 04-02-2002 | 11:42 AM
RickA
Dixie Doug,
Engine is brand new and was fired up a month ago at the machine shop to set the timing and check for leaks. The shop is a certified Merc engine re-builder, so I think it would be safe to say that there would be no oil or water in the cylinders.
I can also crank engine with a bar so I don't think it's hydraulic locked if that is where you were leading.
Pretty sure it's electrical, just not sure where.
Rick
Old 04-02-2002 | 12:00 PM
Wally's Avatar
Were doomed!
Try useing a known good set of jumper cables to bypass the batt wires to the starter. That way you can see if the stock cables are good or not. If it still "clicks" then i would start on the solenoid and go from there.
***Also make sure the bilge area is well vented!!! Dont need anything blowing up with stray sparks!!! *****
I know this aint the best way of testing but when you are trouble shooting it helps to rule out all the easiest first before tearing into everything!!!
-Wally
Wally is offline
Old 04-02-2002 | 12:29 PM
Iggy's Avatar
My starter does the same thing. It will crank after repeated twists of the key. Figured it was the solenoid.
Is there a difference between marine and automotive solenoids?
I know that the automotive ones are sealed to prevent moisture intrusion.
Could I use it in place of the marine unit?
My solenoid is mounted on the starter, standard GM equipment.
Iggy is offline
Old 04-02-2002 | 01:25 PM
Official OSO boat whore
I had a simular problem once. Turned out I forgot to connect the cable to the battery. I had connected a lighter gauge wire that fed the solenoid, but because starter runs directly off the battery, there was no juice to turn it over. As obvious as it appears, it took alot of head scratching to figure out why it would "click" but not turn over.
Cord is offline
Old 04-02-2002 | 02:40 PM
MitchStellin's Avatar
Iggy, it is your slave solenoid on the front of your engine. That might be the same for the 502 problem also. They go over the winter often.
MitchStellin is offline
Old 04-02-2002 | 03:21 PM
Iggy's Avatar
Donzi Mitch,
You saying I have two solenoids?? One on front of the engine as well as the one I know is on the starter?? Hmmm. I'll check the wiring schematic when I get home.
It was like this last season too, but not as bad. It would only click once in a while.
Iggy is offline
