Let's see your Ford or GM do this >
Old 09-05-2009 | 10:16 PM
Default Let's see your Ford or GM do this
At the beginning you can see both axles are in the mud;
http://www.youtube.com/watch?v=Sl7Bla02E9w&NR=1
Catmando is offline
Old 09-05-2009 | 10:50 PM
That truck isn't as stuck as it looks. His left side drives are up on solid ground. Front axle is the driving axle. Once the power devider is locked in, power will go to the rear axle that doesn't slip also.
scarab kv is offline
Old 09-05-2009 | 11:17 PM
You think those Army boys were pulling a fast one? The way I see it the rig doesn't get on solid ground without the Cummins.
Catmando is offline
Old 09-06-2009 | 12:05 AM
So you dont think a Ford or Chevy diesel is capable of spinning tires in 4wd anchored to a semi? The suprising part is that the POS transmission in the Dodge didnt let go. Must have been a 6-speed.
tx911 is offline
Old 09-06-2009 | 12:08 AM
Here you go
http://www.youtube.com/watch?v=7WMGohRlExY
tx911 is offline
Old 09-06-2009 | 08:30 AM
seafordguy's Avatar
Drop my dually in low gear and let the clutch out and I'd have ripped that thing right out.....
It's more about traction.....
seafordguy is offline
Old 09-06-2009 | 09:19 AM
MarkSmith's Avatar
That Catmando is just a trouble maker! lol
MarkSmith is offline
Old 09-06-2009 | 12:28 PM
2112's Avatar
And a non stop Cummins commercial.
2112 is offline
Old 09-06-2009 | 08:00 PM
Audiofn's Avatar
Charter Member #232
Cat I pulled out a truck like that with a hydrolic boat trailer and a 48 foot cruiser attached to it up a 45 degree ramp and barely had to touch my gas pedle.
Put your best foot forward!
Audiofn is offline
Old 09-06-2009 | 08:27 PM
ROFL
Catmando is offline
