-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Let's see your Ford or GM do this (https://www.offshoreonly.com/forums/trucks-trailers-transportation/216325-lets-see-your-ford-gm-do.html)
Catmando 09-05-2009 10:16 PM
At the beginning you can see both axles are in the mud;
http://www.youtube.com/watch?v=Sl7Bla02E9w&NR=1
scarab kv 09-05-2009 10:50 PM
That truck isn't as stuck as it looks. His left side drives are up on solid ground. Front axle is the driving axle. Once the power devider is locked in, power will go to the rear axle that doesn't slip also.
Catmando 09-05-2009 11:17 PM
You think those Army boys were pulling a fast one? The way I see it the rig doesn't get on solid ground without the Cummins.
tx911 09-06-2009 12:05 AM
So you dont think a Ford or Chevy diesel is capable of spinning tires in 4wd anchored to a semi? The suprising part is that the POS transmission in the Dodge didnt let go. Must have been a 6-speed.
tx911 09-06-2009 12:08 AM
Here you go
http://www.youtube.com/watch?v=7WMGohRlExY
seafordguy 09-06-2009 08:30 AM
Drop my dually in low gear and let the clutch out and I'd have ripped that thing right out.....
It's more about traction.....
MarkSmith 09-06-2009 09:19 AM
That Catmando is just a trouble maker! lol:evilb:
2112 09-06-2009 12:28 PM
And a non stop Cummins commercial. :party-smiley-004:
Audiofn 09-06-2009 08:00 PM
Cat I pulled out a truck like that with a hydrolic boat trailer and a 48 foot cruiser attached to it up a 45 degree ramp and barely had to touch my gas pedle.
Catmando 09-06-2009 08:27 PM
ROFL :bsflag: :D
