Sealant for risers gaskets? (Cast Merc) >
Old 04-05-2002 | 08:27 AM
patrick22309
Question Sealant for risers gaskets? (Cast Merc)
I plan to split my riser from my manifold this evening to investigate my water flow problems and am not sure what to use to put them back together. I have NEW gaskets but not sure if they require and sealant?
Old 04-05-2002 | 08:31 AM
patrick22309
By the way, any of you guys know Art Lilly? I am asking all these question about a Stingray boat I purchased from him. He is a good guy and let me know of problem areas before I purchased the boat.
Old 04-05-2002 | 09:03 AM
ursus
Merc service bulletin for exhaust manifold and risers, it sugests Loctite 510 sealent, good info to read for inspecting reassembly procedure
http://www.sterndrives.com/bulletins/mc/99/EN_010.PDF
Old 04-05-2002 | 12:18 PM
Mbam's Avatar
Offshoreonly Advertiser
The latest gasket is a graphite composite and does not use any sealer. It is kind of silver metallic looking. The sealer was a previous setup. I is best to use the new gasket, seems to work better than the previous versions.
Mbam is offline
Full Force
Swap Shop
3
11-02-2008 12:35 PM
Full Force
Swap Shop
2
09-14-2008 08:01 AM
35 White Lightning
3
05-14-2007 01:09 PM
Whiteknuckle
9
01-09-2003 11:27 AM
