What Gear lube are you running in your TRS
Read this, and I bet you'll reconsider using it.
http://www.amsoil.com/products/gearl...hitePaper.aspx
For another company to put someone's name on tests, they better be right, otherwise they'll be facing some serious consequences.
Great Article! Thanks!
I am going to go with the royal purple gear lube. It is called Max-gear correct? Which weight should I run and anyone know the capacity for a TRS drive?
