outdrive oil, whats the difference??? >
Old 10-06-2009 | 06:03 PM
Default outdrive oil, whats the difference???
ok,whats the real difference between quicksilver outdrive oil 80w-90 versus regular performance gear oil with same viscosity? i was at bass pro today and they wanted frikin 13.99 a quart of the quick silver brand, and right next to it was penzoil lower unit oil same viscosity for only 4.99 each, what gives??
ricric is offline
Old 10-06-2009 | 08:46 PM
GO4BROKE's Avatar
Do a search here and in the out drive forum, lots of info. Short story, most have switched to amsooil or mobil 1.
[img][/img]
GO4BROKE is offline
Old 10-06-2009 | 11:01 PM
Rebel_Heart's Avatar
A lot depends on your hp and what you are asking your drives to do. I switched to Royal Purple when I substantially increased power.
Rebel_Heart is offline
Old 10-07-2009 | 06:14 AM
If you run an 80w-90 GL-5/hypoid product it will more than work. If you must buy on price, then the spec is the spec, buy on price. Of course, there are better products on the market.
Ken
minxguy is offline
Old 10-07-2009 | 08:20 AM
Here is some good reading material. This will answer a lot of your questions..........
http://www.amsoil.com/products/gearl...hitePaper.aspx
07DominatorSS is offline
Old 10-07-2009 | 11:04 AM
thanks guys/gals for the gear lube tips!!
ricric is offline
Old 10-07-2009 | 11:55 AM
c_deezy's Avatar
So long story short Amsoil is the better choice over the Merc green stuff?
c_deezy is offline
Old 10-07-2009 | 01:15 PM
Depends who you talk to. It's what I use.
Irishtornado is offline
Old 10-07-2009 | 01:34 PM
c_deezy's Avatar
I only use the merc stuff because its green and I like the color. No other reason, whatsover
c_deezy is offline
Old 10-07-2009 | 02:04 PM
CPPerformance's Avatar
We offer high quality Swepco Gear Oil, used not only in high performance boating applications but the harsh environments of Nascar and Baja Trophy Trucks also.
http://www.cpperformance.com/detail.aspx?ID=9590
CPPerformance is offline
