Best Way to Change Oil Filter Without Making a Mess? >
Old 11-04-2009 | 08:17 PM
bn
Default Best Way to Change Oil Filter Without Making a Mess?
Just wondering what the best way is to change the oil filter without having oil drip all over the place?
Never understood why Merc puts the filter upside down.
bn is offline
Old 11-04-2009 | 08:22 PM
What kind of engines are you running?
With the 496HO/496, which have the oil drain tube through the drain plug hole it make it much easier.
I run the engines on the hose for about 5 minutes to heat the oil up, shut it off, open the drain plug, pop the oil cap and loosen the oil filter. Works perfectly without any mess. No oil left in the filter when I remove it.
MC-BOYS is offline
Old 11-04-2009 | 08:25 PM
Arrow
Drain the oil when it's still hot/warm. Puncture a couple of holes in the top of the filter to allow the oil to drain out of it faster.
That's how I do it and am sure lot of others.
spectras only is offline
Old 11-04-2009 | 08:32 PM
Here's what I do, and it works well:
Do you drink coffee? The coffee I drink at home is the Target brand, they call it Market Pantry. Anyway, I buy the big can, got one here in front of me. It is the 2lb 7oz. can. I save them when they are empty, and for changing the oil filters in the boat is the main reason.
What I do is stuff a few blue shop towels in the bottom, I position and hold the can under the filter with one hand, and unscrew it with my other. I slowly unscrew it and gently lower it into the coffee can, while letting the residual oil drain in. I then take a few more blue shop towels and stuff them up into the oil filter mount to keep any oil from dripping until I am ready to screw on the new filter.
I take the coffee can with the old filter in it and pop on the lid. That keeps everything contained until I get back to my bench where I can drain it into a pan. Works well.
BowenCT is offline
Old 11-04-2009 | 08:41 PM
bn
[QUOTE=MC-BOYS;2985595]What kind of engines are you running?
QUOTE]
502 MPI's
bn is offline
Old 11-04-2009 | 08:42 PM
All I do is crack the filters loose a bit and let them sit while I pump the oil out. By the time that is done, I just spin them off and they are empty. No mess what so ever. This is with 502 Mag MPI engines
BGIII is offline
Old 11-04-2009 | 08:51 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
A few tips here:
http://www.offshoreonly.com/forums/f...equipment.html
http://www.offshoreonly.com/forums/g...er-change.html
http://www.offshoreonly.com/forums/f...r-removal.html
Sydwayz is offline
Old 11-04-2009 | 10:05 PM
eddie's Avatar
I warm the motors, punch a hole in the filters then suck the oil out of the dipstick tube. No mess.
eddie is offline
Old 11-04-2009 | 10:38 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I also do as BGIII mentioned. Works great and not a drop spilled. You unscrew the filter just enough to break the gasket seal. The flow from the oil draining down will actually create a suction inwards. You'd swear it's going to just run all out the crack, but it doesn't.
US1 Fountain is offline
Old 11-04-2009 | 10:54 PM
Smile
Bowen , he has upside down filters like I have >
